ArchLand00042.pngSite Model Modification Overview
The Site Modifiers tool is in the Site Planning tool set.
As discussed in Sitework Overview, when the site model is generated, two different display modes of the site model object are available—existing and proposed. The existing site represents the site prior to your project; the proposed site incorporates the project’s changes. To modify the site model, use the Site Modifiers tool, along with other site modification tools in the Vectorworks program; a site modifier can be applied to either the existing or proposed site model.
The Site Modifiers tool has several modes.
Mode
Description
Grade Limit
Defines an area of topographical transition between existing site data and the site modifiers enclosed within the limits
Contour
Creates an open path site modifier, representing a contour line at a constant elevation
Pad
Draws a closed area which modifies the site model
Pad with Retaining Edge
Creates a pad with an edge around it, allowing the terrain to be shaped around the pad
Texture Bed
Creates an area of the site model that can be textured
Spoil Pile
Creates an area where excess earth can be used to help balance the cut and fill
Snap to Contour Elevation
Constrains the site modifier to the site model contour elevation under the cursor when the site modifier is created. The contour under the cursor is highlighted, and the elevation of that contour is used as the modifier elevation.
Polyline creation options
Selects the method for drawing the polyline upon which the site modifier is based; see Creating Polylines.
Preferences
Sets the default preferences for the site modifier
Pad Elev
When creating a pad, pad with retaining edge, contour, or spoil pile, specify the elevation of the site modifier
Site modifiers can be placed on any layer. The site model properties specify whether modifiers in another layer can affect the site model (see Creating the Site Model). You might put various site modifiers on separate layers, for example, so that you can show each modifier’s effect on the site model individually. When a site modifier is placed in the drawing, the Site-DTM-Modifier class is created automatically.
In addition to the site modifiers that are created with the Site Modifiers tool, a number of other tools and commands create objects that can modify the site model.
Creating a Pad or Pad with Retaining Edge
Creating a Contour
Creating Grade Limits
Creating a Spoil Pile Area
Creating a Texture Bed
Creating Roads
Creating NURBS Roadways
Creating Landscape Walls
Creating Hardscape Objects
Showing and Hiding Site Modifiers
Correcting Site Modifier Errors
Creating Property Lines
Analyzing the Site Model
Obtaining Site Model Data
vectorworks.net
