In the Vectorworks Landmark product, 3D loci can be converted to stake objects, which can then be used to modify a site model. This is useful when survey data, in the form of 3D loci, need to modify an existing or proposed site model.
To create stake objects from 3D loci:
Select the 3D loci.
Select Modify > Convert > Stake Object from 3D Locus.
The Convert to Stake Object dialog box opens. Set the properties for new stakes.
Click OK to create the stake objects.
If the stake objects are site modifiers, update the site model to apply the changes (select the site model and click Update from the Object Info palette).
See Inserting Stake Objects for additional stake object parameters that can be edited from the Object Info palette.
