Palette Layout Options
Customize the palette layout.
    Select Window > Palettes to display or hide palettes. Alternatively, right-click (Windows) or Ctrl-click (Mac) on the drawing area, and select Palettes from the document context menu.
    Click the title bar of any displayed palette and drag it to the desired location.
    Most palettes can be resized by the standard Windows or Mac resize method.
    Palettes can be docked to the application window (see Docking Palettes).
Each time you exit the Vectorworks program, the current palette settings and positions are automatically saved for each workspace in a file in your user folder ([User]\Settings\SavedSettings.xml). The settings in this user file override the initial palette settings in the workspace file. To reset to the original workspace settings, click Reset Saved Settings from the Session tab of Vectorworks preferences (see Vectorworks Preferences: Session Tab).
Specifying Mac Palette Margins
On the Mac, the palettes can be placed in a margin on either side of the drawing area. When the palette margins are in use, the drawing area cannot expand past a fixed size, which allows the palettes to remain out of the way. The palette margin area can be turned on and off in the Vectorworks preferences as described in Vectorworks Preferences: Session Tab.
Minimizing Palettes
To increase the available drawing area, palettes that are not docked can be minimized while not in use, and then maximized when needed.
On Mac, click the plus/minus sign in the title bar to toggle between minimized (minus sign) and maximized (plus sign) display.
On Windows, click the palette’s pin icon in the title bar to toggle between minimized (horizontal pin icon) and maximized (vertical pin icon) display.
Move the cursor over a minimized title bar to temporarily maximize the palette; move the cursor off the palette to minimize it again. On Mac, to enable this feature, select Window > Palette Options > Auto-Hide Floating Palettes.
Tool Palette Features
Application Window
vectorworks.net
