Updating Viewports
Changes that affect the appearance of a viewport are automatically updated for a wireframe viewport. However, if changes require the viewport to be rendered again, the viewport will be displayed as an out-of-date viewport.
If a sheet layer with an out-of-date viewport is printed, a message prompts you to either print the viewport as an out-of-date viewport or update the viewport on the sheet layer before printing.
Rendered viewport updates occur in the background for Renderworks render modes; you can continue working in the file while the viewports are updating. See Background Rendering.
Updating Selected Viewports
To update selected viewports:
  1. Select the viewports.
  2. From the Object Info palette, click Update. Alternatively, select View > Update Selected Viewports.
  3. Alternatively, right-click (Windows) or Ctrl-click (Mac) on the viewport and select Update from the context menu.
  4. The selected viewports are updated.
Updating All Viewports
To update all the viewports in the file:
  1. Select View > Update All Viewports.
  2. All viewports on all sheet layers are updated.
Canceling Viewport Updates
To cancel the updates of all viewports, including those queued to update for background rendering:
  1. Select View > Cancel All Viewport Updates.
  2. The updates are canceled.
Viewport Status
Modifying Viewports
Viewport Properties
vectorworks.net
