ArchLand00044.pngCreating Elevation Benchmarks
Use the Elevation Benchmark tool to indicate the height of an object in an elevation drawing. Two elevation benchmark styles are available: ISO and US.
To create an elevation benchmark:
  1. Click the Elevation Benchmark tool from the Dims/Notes tool set.
  2. Click to place the object in the drawing, and click again to set the length and rotation.
After creation, multiple elevation benchmark objects can be aligned and distributed with the Align/Distribute Leader Lines command; see Aligning and Distributing Leader Lines.
Using Notation Objects
