DXF/DWG and DWF Export Options
The DXF/DWG Export Options dialog box and the DWF Export Options dialog box are very similar, except for the file format settings. This is because when you export to DWF, the drawing objects are first converted to DXF/DWG, and then output in DWF format. Change the export options to retain the integrity of the Vectorworks drawings in the DXF/DWG format. The same export options display for export of single files and batches of files.
To make custom exports faster and easier, save the sets of options that you use frequently.
Line Thickness Conversions
VW Line Thickness (mm)
DXF Line Weight (mm)
0
Deleted
0.52–0.56
0.53
0.01–0.07
0.05
0.57–0.65
0.60
0.08–0.11
0.09
0.66–0.75
0.70
0.12–0.14
0.13
0.76–0.85
0.80
0.15–0.16
0.15
0.86–0.95
0.90
0.17–0.19
0.18
0.96–1.03
1.00
0.20–0.22
0.20
1.04–1.13
1.06
0.23–0.27
0.25
1.14–1.30
1.20
0.28–0.32
0.30
1.31–1.49
1.40
0.33–0.37
0.35
1.50–1.75
1.58
0.38–0.45
0.40
1.76–2.05
2.00
0.46–0.51
0.50
2.06–6.48
2.11
