Import Options: Location Tab
Depending on the coordinates of the imported file, objects in the file might be located far from the drawing’s internal origin, which can cause issues with OpenGL rendering and with calculation precision due to rounding errors. It is best to center the first import about the internal origin at import, and align subsequent imports with the user origin. This is the recommended option. Normally, the internal origin and the center of the page are coincident, so this option also centers the objects to the page center.
Internal Origin and User Origin
Import Options: Primary Settings Tab
Import Options: Graphic Attributes Tab
Import Options: Objects Tab
DXF/DWG and DWF Import Options
Managing Saved Import Options
