Combining and Connecting Objects
Connect/Combine Tool
The Connect/Combine tool is in the Basic palette.
The Connect/Combine tool joins objects by their endpoints or at their intersections using one of four modes.
Mode
Description
Single Object Connect
Trims or extends the first selected object to join a second or boundary object
This mode can be used for Connecting Roof Faces.
Dual Object Connect
Trims or extends to join two objects at their endpoints or intersections
Dual Object Combine
Trims or extends to join two objects into one object at their endpoints or intersections
Multiple Object Connect
Designates the first selected object as a boundary, and then trims or extends multiple consecutively selected objects to join the boundary
Miter Roof Face Joins
When you are Connecting Roof Faces, miters the faces at the join
Vertically Cut Roof Face Joins
When you are Connecting Roof Faces, cuts the faces vertically at the join
When connecting or combining a pair of NURBS, polylines, or open polygons by their endpoints, you may need to supply additional information to complete the process. In this situation, the Connect/Combine Options dialog box opens.
Option
Description
Mid-Point
Connects/combines the two objects by joining the two endpoints midway between them
Blend
Connects/combines the two objects by creating another object between them
Position Matching
(NURBS curves and surfaces only)
Connects/combines two NURBS curves or surfaces by moving the first object’s selected end point to the selected end point of the boundary object (not available if the end points are coincident)
Tangency Matching
Connects/combines two NURBS curves or surfaces by making the first object’s selected end point tangent to the selected end point of the boundary object
Curvature Matching
Connects/combines two NURBS curves or surfaces by making the first object’s selected end point match the curvature of the selected end point of the boundary object
Dual Object Connect
Dual Object Combine
