DesignSeries00026.pngAdding and Editing Drawing Issues
Issues can be added to a drawing file, and existing issues can be edited, from the Title Block Border Settings: Issue Data Pane or from the Issue Data tab of the Title Block Manager (see Preparing to Publish with the Title Block Manager). Adding issues from the Title Block Manager dialog box allows you to add sheets located in other files to the issue; this can help to coordinate large projects.
To add or edit an issue:
  1. If the issue applies to only a specific sheet, make that the active layer.
  2. Do one of the following:
  3. ●    Click on the title block border object, and then click Title Block Border Settings from the Object Info palette to open the Title Block Border Settings dialog box. Select the Issue Data pane from the list on the left.
    ●    Select File > Title Block Manager. For Title Block on Layer, click <Prev or Next> until the correct sheet layer displays. Click the Issue Data tab.
  4. To add an issue, click Add, or to edit an existing issue, select the issue from the list and click Edit.
  5. The Add New Issue or Edit Existing Issue dialog box opens. Enter the parameters.
  6. If the Select Files dialog box opens, you can apply the issue to sheets in other files. Click Select Folder and browse to the folder with the files to select.
  7. The list browser displays the .vwx files located in the folder.
  8. Click the disclosure arrows if necessary to display or hide the individual sheets within a file. Click to place a check mark in the Use File column to the left of the files or sheets to add; entire files or specific sheets can be included in the issue.
  9. Selecting a file automatically selects all the sheets in the file.
  10. Click OK to return to the issue dialog box, and then click OK.
The issue is added to the list.
Adding a Title Block Border
Top-Aligning Revision and Issue Text in the Title Block Layout
Creating Project Revision and Issue History Reports
