Adding a Title Block Border
Title block borders both provide the graphic layout of the sheet border and title block and manage the data required for the title block, revision block, issue block, publish sets, and so on, as described in Concept: Using Title Block Borders.
To place a title block border on a sheet layer:
  1. Click the Title Block Border tool from the Dims/Notes tool set.
  2. Do one of the following:
  3. ●    To use an existing title block border from the resource libraries, click Title Block Border Style on the Tool bar. From the Resource Selector, double-click a resource to activate it.
    ●    To create a custom title block border, click Preferences from the Tool bar. From the Title Block Border Preferences dialog box, set the default properties and click OK. The properties can be edited by clicking Title Block Border Settings from the Object Info palette.
  4. Click on the drawing to place the object, and click again to set the rotation.
A title block border object is placed on the drawing.
Click Title Block Border Settings from the Object Info palette of a selected title block border to open the Title Block Border Settings dialog box.
Creating Plug-in Object Styles allows you to create plug-in objects, such as the title block border, with a combination of parameters that are determined by the style or by instance. Style parameters have a fixed value established by the style; instance parameters can be set independently for each instance of the object in the drawing.
The selected object’s settings are grouped into several panes of related parameters, which are listed on the left side of the Title Block Border Settings dialog box. Select each pane and specify the parameters. Click OK to set the parameters and close the dialog box.
Title Block Border Settings: Sheet Border Pane
Title Block Border Settings: Sheet Zones/Grids Pane
Title Block Border Settings: Title Block Pane
Title Block Border Settings: Project Data Pane
Project-wide data shared by all title block borders are managed from this pane; changes made to the Project Data pane of any title block border in the file are made to all title block borders in the file.
Title Block Border Settings: Sheet Data Pane
Sheet-specific data are managed from this pane.
DesignSeries.pngTitle Block Border Settings: Revision Data Pane
Depending on the length of the revision entries, they may need to be top-aligned in the revision section of the title block border; see Top-Aligning Revision and Issue Text in the Title Block Layout.
DesignSeries00024.pngTitle Block Border Settings: Issue Data Pane
Depending on the length of the issue entries, they may need to be top-aligned in the revision section of the title block border; see Top-Aligning Revision and Issue Text in the Title Block Layout.
Title Block Border Settings: North Point Pane
Title Block Border Settings: Drawing Stamp Pane
Title Block Border Settings: Document Options Pane
The revision and issue number options apply to all layers in the file.
Editing a Title Block Border
Preparing to Publish with the Title Block Manager
Creating Project Revision and Issue History Reports
Changing Title Block Border Styles from the Object Info Palette
