Title block border styles applied to existing title block borders can be replaced or edited from the Object Info palette.
To replace the style of a selected title block border:
Select one or more title block borders.
From the Object Info palette, select Replace from the Style list.
The Choose a Plug-in Style dialog box opens.
Select the new title block border style and click OK. The replacement style is applied to all selected title block borders.
To edit the style of all title block borders with the style:
Select a title block border.
From the Object Info palette, select Edit Style from the Style list.
The Title Block Border Style dialog box opens.
Edit the current style, as described in Creating Plug-in Object Styles.
Editing a title block border style modifies all title block border instances in the drawing that use that style.
To convert the title block border instance to unstyled:
From the Object Info palette, select Convert to Unstyled from the Style list.
The title block border’s current values are retained, but all parameters are set to By Instance to allow editing.
