ArchLand00010.pngCreating the Site Model
Creating a Site Model from the Source Data
Once source data has been obtained for the site model, the site model can be created. After generation, the site model is cached by default so that updating occurs more efficiently; however, large file sizes can result. See Document Preferences: Display Tab for information on changing the default setting.
To create a site model from source data:
  1. Ensure that valid source data exists. The site model can be created from 3D loci, 3D polygons, stake objects, or by one of the methods described in Site Model Source Data. Verify that there are no problems with the source data with the Validate 3D Data command (see Validating 3D Source Data).
  2. Select the source data.
  3. Select the Create Site Model command from the appropriate menu:
  4. ●    Architect workspace: AEC > Terrain > Create Site Model
    ●    Landmark workspace: Landmark > Create Site Model
    The Site Model Settings dialog box opens. Specify the site model parameters.
    Site Model Settings
    Site Model Settings: General Pane
    Site Model Settings: 2D Display Pane
    Site Model Settings: 3D Display Pane
  5. Click OK.
A site model is created in the active layer and displays as specified.
Setting Site Model Graphic Properties
Site Model Properties
Creating a Site Model Snapshot
Site Model Modification Overview
