Controlling RLM Options
The RLM server handles the core functions of license management while the ISV server manages specifics about the Vectorworks program licenses. The section on Specifying Server Options details how to create groups of users, computers, and IP addresses for assigning Vectorworks-specific ISV privileges. This section provides similar instructions on assigning privileges to groups through the RLM options.
The privileges that can be assigned or restricted are defined in Requiring Server Passwords.
To specify and edit the privileges assigned to users or groups:
  1. From the main Server Administration screen, click Status.
  2. The server status pane displays.
  3. Click EDIT rlm Options.
  4. The Edit RLM Options screen opens.
  5. Using the syntax described in Server Syntax, specify or edit the rlm options.
  6. In the syntax and examples, user, host, internet, group, host_group, and internet_group can be specified interchangeably when setting up permissions for a client or groups of clients.
    Command
    Description
    Syntax
    Excludeall
    Does not allow any privileges for specific clients
    EXCLUDEALL group group_name
    Example: EXCLUDEALL group interns
    Exclude
    Restricts the specified privilege for a client
    EXCLUDE privilege user name
    Example: EXCLUDE remove name sam
    Includeall
    Allows the use of all privileges for specific clients
    INCLUDEALL host_group group_name
    Example: INCLUDEALL status host_group IT
    Include
    Specifies privileges for a client
    INCLUDE privilege internet IPaddress
    Example: INCLUDE shutdown Internet 172.67.94.13
  7. Click Update Options.
The options are saved in the rlm.opt file, which is located in the same network license folder as the RLM software.
The Debug Log
