Specifying Server Options
The system administrator can control the module and the licensed user options; for example, some users may not be allowed to borrow Vectorworks, or may only borrow it for shorter periods of time than other users. The administrator can also set report log and debug log file options.
The most convenient way to manage user permissions and modules is to use the System Menu for Configuring Access Permissions. It is also possible to use the browser interface, as described below, although this is not recommended.
If there are many users that will not be allowed to borrow the software, instead of excluding each one, use INCLUDEALL_ROAM to allow only specific users to borrow.
To specify and edit the module, user, or log file options:
  1. From the main Server Administration screen, click Status.
  2. The server status pane displays.
  3. In the Options column of the ISV Servers table, click vektorwrx.
  4. The Edit ISV Options screen opens.
  5. Using the syntax described in Server Syntax, specify or edit the user options.
  6. In the syntax and examples, user, host, internet, group, host_group, and internet_group can be specified interchangeably when setting up permissions for a client or groups of clients.
    Command
    Description
    Syntax
    roam_max_days
    Restricts the borrowing feature for a certain number of days (up to 30 days) and for certain modules
    ROAM_MAX_DAYS days module
    Example: ROAM_MAX_DAYS 3 architect
    roam_max_days -
    Disables the borrowing feature for certain modules (use a negative number to prevent borrowing)
    ROAM_MAX_DAYS -1 module
    Example: ROAM_MAX_DAYS -1 landmark
    Exclude
    Restricts the use of a module for the specified client
    EXCLUDE module user name
    Example: EXCLUDE landmark user sam
    Include
    Restricts the use of a module for any clients not specified
    INCLUDE module group group_name
    Example: INCLUDE spotlight group designers
    Excludeall_roam
    Restricts borrowing for certain clients
    EXCLUDEALL_ROAM user firstname_lastname
    Example: EXCLUDEALL_ROAM user susan_rodriguez
    Includeall_roam
    Allows borrowing for certain clients
    INCLUDEALL_ROAM group group_name
    Example: INCLUDEALL_ROAM group architects
    Reserve
    Reserves licenses for critical clients
    RESERVE number module user user_name
    Examples: RESERVE 1 spotlight user elena
    RESERVE 3 architect group engineers
    Max
    Limits the maximum number of licenses checked out per client
    MAX number module user firstname_lastname
    Example: MAX 3 landmark host_group designers
    Debuglog
    Opens the Debug log for the ISV server
    DEBUGLOG file_path file_name
    Example: dbuglog Log\dlog.txt
    Debuglog +
    Creates a different Debug log for each ISV server, automatically appending the log information rather than overwriting the log; this can also be specified as a startup option. See Server Startup Options.
    DEBUGLOG + file_path file_name
    Example: dbuglog + Log\dlog.txt
    Nolog in
    Nolog out
    Nolog denied
    Specifies that the server won’t log information about license check ins, check outs, or denied licenses in the Debug log
    NOLOG type
    Example: NOLOG denied
    Reportlog
    Saves license usage information to a log file
    REPORTLOG file_path_file_name type
    Windows example: REPORTLOG Log\Reportlog.txt detailed
    Mac example: REPORTLOG Log/Reportlog.txt std
    Rotate
    Saves and closes the current report log, creating a new log
    ROTATE [daily|weekly|monthly|#days]
    Example: ROTATE daily
  7. Click Update Options.
The options are saved in the vektorwrx.opt file, which is located in the same network license folder as the RLM software.
Server Status Screen
Main Server Administration Screen
The Report Log
The Debug Log
Requiring Server Passwords
Controlling RLM Options
