Configuring Access Permissions
To view and configure access permissions:
  1. Select Access Permissions from the site protection System Menu.
  2. The Access Permissions dialog box opens, listing permissions rules for groups of users. Rules are sets of allowed and/or reserved products that apply to specific users or computers.
  3. Set up the permissions rules for groups of users by selecting Add Rule from the Rules menu at the top of the dialog box, or right-click in the rules area and select Add Rule from the context menu.
  4. The Add/Edit Rule dialog box opens.
  5. “Users” can represent user names, computer names, or IP addresses. Define the needed rules for groups of users; for example, certain groups may only be permitted to use the Architect and Fundamentals products, while other users can only use Landmark and Fundamentals. If no products are selected, the users in the list cannot connect to the server at all. Licenses can also be reserved for groups of users. Each of these situations requires an individual rule for each group.
  6. Click OK to return to the Access Permissions dialog box.
  7. Edit a selected exiting rule by selecting Edit Rule from the Rules menu at the top of the dialog box, double-clicking on a rule, or right-click on a rule and select Edit Rule from the context menu.
  8. Delete a selected exiting rule by selecting Delete Rule from the Rules menu at the top of the dialog box, or right-click on a rule and select Delete Rule from the context menu.
  9. Click OK to close the Access Permissions dialog box.
Site Protection Server Administration from a Web Browser
Although using the site protection System Menu is recommended, you can perform Site Protection Server Administration from a Web Browser to access all of the Administration functions and to perform various license management duties from a remote location.
Reprise software contains many options. Several of the options can be accessed from multiple locations. Some options are not used at all by the Vectorworks Site Protection Server. The functions described here are covered in greater detail in the RLM user’s guide, RLM_Enduser.html. You can also access the guide by clicking RLM Manual from the main Server Administration screen.
Access to the various server functions can be controlled with a password file; see Requiring Server Passwords.
Main Server Administration Screen
Specifying Server Options
