DesignSeries00091.pngEditing Wall Features
Similar to symbols, the original 2D or 3D object (or symbol) can be edited after the wall feature is created. For example, the location or shape of the object can be changed.
To access the editing mode, double-click the wall feature. Alternatively, right-click on the feature and select Edit from the context menu. To delete the wall feature, delete the original object from which the wall feature was created. Click Exit Wall Feature to exit the editing mode.
Also similar to symbols, wall features can be moved and duplicated in various ways in both straight and round walls. See the following topics:
●    Moving Symbols in Walls with the Selection Tool
●    Moving Symbols in Walls with the Move Command
●    Moving Symbols in Walls with the Move by Points Tool
●    Duplicate Array
Creating Wall Projections
Creating Wall Features
Creating Walls
