DesignSeries00031.pngEditing Wall Styles
To edit a straight or round wall style:
  1. From the Resource Manager, right-click on the resource, and select Edit from the context menu.
  2. Alternatively, select Edit Style from the Style menu of the Object Info palette, or right-click on the wall and select Edit Wall Style from the context menu.
    The Edit Wall Style dialog box opens.
  3. Edit the wall and component parameters as described in Creating Walls, and Drawing Straight Walls.
  4. If a new wall style Name is specified, it replaces the selected wall style name (similar to selecting Rename from the Resources menu).
  5. Click OK.
  6. If walls with that style already exist in the drawing, the Wall Replacement dialog box opens.
  7. The wall style to apply cannot be selected (the edited style is applied). Select the wall alignment properties (see Replacing Wall Styles from the Object Info Palette).
  8. Click OK to edit the wall style.
Changes apply to any existing walls in the drawing with the edited wall style, and will be used for any subsequent walls created with that wall style.
Applying Wall Styles
Deleting and/or Replacing Wall Styles from the Resource Manager
