Removing Wall Breaks
The Remove Wall Breaks tool cleans up any wall breaks or gaps that were created during editing. For example, when creating a new wall that joins an existing wall, if the new wall is later deleted, a break in the remaining wall displays at the joint. The Remove Wall Breaks tool can remove the break and any end caps.
To remove wall breaks:
  1. Click the Remove Wall Breaks tool from the appropriate tool set:
  2. ●    Fundamentals workspace: Walls tool set
    ●    Design Series workspaces: Building Shell tool set
    Alternatively, right-click on the wall and select Remove Break from the context menu.
  3. Click and drag to create a marquee box around the wall break or end cap to remove.
The wall break or end cap is automatically removed.
Reshaping Walls
Joining Walls
Joining Walls with the Fillet Tool
