Reshaping Walls
Use the Reshape tool in a 3D view to edit the wall height, change the elevation of wall peaks, add vertices to create peaks in a wall, and delete vertices that have been added. Wall peaks can also be removed with the Delete Wall Peaks command. Use the Selection tool to change the wall length. Symbols remain where placed when a wall is reshaped.
In the following situations, the Reshape tool displays 2D Reshape modes; the vertices at either end of the wall can be moved, to change the wall length and/or location. See 2D Reshape Modes.
●    In Top/Plan view
●    When multiple walls are selected
●    When a wall and other objects are selected
●    When a marquee has been drawn
In any 3D view, when only a single wall is selected, the Reshape tool has three modes available.
Mode
Description
Reshape 3D Walls
Adjusts the position of a selected wall vertex
Add 3D Wall Peaks
Adds a vertex to a wall for reshaping purposes
Delete 3D Wall Peaks
Deletes a wall vertex
Walls can also be trimmed using the Trim tool; see Trim Tool.
Changing Wall Length
Changing Wall Height
Changing Wall Peak Height
Adding a Wall Peak
Deleting Wall Peaks
Reshaping Objects
Changing Round Wall Radius
Removing Wall Breaks
Joining Walls
Joining Walls with the Fillet Tool
Wall Insertion Mode
Creating Walls
