Spot00082.pngClearing Calculation Results
Command
Path
Clear Calculation Results
Braceworks
The Clear Calculation Results command is available for Vectorworks Spotlight software but is not present in the Spotlight workspace. It can be added to the Spotlight workspace (see Customizing Workspaces).
The results from the most recently executed calculation (Braceworks required) or system check command are retained and display in the Calculation Overview dialog box. These results can be cleared with the Clear Calculation Results command.
To clear calculation results:
Select the command. All calculation results and any resulting issues are cleared. Any issue labels in the drawing are removed, and any color coding of hoist labels reverts to red.
Performing Calculations
Performing System Check Calculations
Generating and Exporting Calculation Reports
