Braceworks00085.pngGenerating and Exporting Calculation Reports
Completed calculations can be shared with colleagues, clients, and structural engineers by sending the results to a customized report in a PDF file, or exporting them to DSTV format.
Creating a Calculation Report
Command
Path
Create Calculation Report
Braceworks
A comprehensive report of the calculations can be generated as a PDF file.
To create a calculation report:
  1. Select the command.
  2. The Create PDF report dialog box opens. Cycle through each pane in order with the <Back and Forward> buttons to create and customize a complete report.
    The system must be solvable to be able to create a report.
  3. When all items in each pane have been addressed, click Create PDF to create the report. Provide a name and location to save the file.
Exporting Calculation Results
