Command |
Path |
Export DSTV |
Braceworks |
To export the results of the last calculation to an .stp file in DSTV format:
Select the command.
The Settings dialog box opens.
From the Load Combination list, select <No Load Combination> or choose a load combination. The icon next to the combination indicates whether it is class- or layer-based.
Select whether the exported results should include all rigging objects in the drawing, or only a subset of selected or visible objects.
Click OK.
Specify a file name and location for saving the file, and click Save.
