DesignSeries00004.pngDrawing Slabs Manually
Mode
Tool
Tool set
Modes for the Polyline Tool
Slab
Building Shell
To draw a manual slab object that is not associated with any walls:
  1. Click the tool and the Polyline mode.
  2. A slab can also be created by drawing a polyline and then selecting the Create Objects from Shapes command (see Creating Objects from Shapes).
  3. Do one of the following:
  4. ●        To use an existing slab style from the resource libraries, click Slab Style from the Tool bar. From the Resource Selector, double-click a resource to activate it. Or, to draw an unstyled slab, leave the <Unstyled> setting as is. Proceed to step 4.
    ●        To create a custom slab style, click Preferences. From the Slab Preferences dialog box, set the default properties (see Creating Slab Styles). The properties can be edited from the Object Info palette.
  5. Similarly to drawing a polygon, create a closed slab shape.
Double-click while drawing to close the slab automatically.
Slab Properties
Concept: Automatically Bounded and Manual Slab Edges
Creating Automatically Bounded Slabs from Existing Walls
Creating Slabs with Both Automatically Bounded and Manual Edges
Converting Slab Boundary Associations
Setting Edge Offsets
Using Slab Styles
Creating Slab Components
Editing Slab Geometry
Creating Slabs
