Editing Roof Objects
Once a roof object has been created, there are multiple ways to edit it:
●        Change roof edge shapes (such as hip or gable) using the Selection tool and the Edit Roof Settings dialog box (Vectorworks Design Series required).
●        Create cutouts in the roof using the Clip tool or Clip Surface command.
●        Reshape the roof object using the Reshape tool.
●        Add an accessory: attic, soffit, or fascia (Vectorworks Architect required)
Additionally, the roof object parameters can be edited from the Object Info palette. Wall settings from the Object Info palette apply to all gable or Dutch hip walls in the roof; to adjust each gable wall individually, use the Edit Roof Settings dialog box.
Changing the Roof Edge Shape
Reshaping Roof Objects
Adding Roof Elements to Roof Objects and Roof Faces
Creating Cutouts in a Roof Object
Adding Roof Accessories
Using Roof Styles
Creating Roof Components
Roof and Wall Associations
