Land00013.pngCreating Hardscape Objects
Mode
Tool
Tool set
Modes for the Polyline Tool
Hardscape
Site Planning
A hardscape object consists of paved areas with joint patterns and optional borders. A boundary hardscape or pathway hardscape can be created. To draw a hardscape object, either use the Hardscape tool, or create a polyline and then select the Create Objects from Shapes command (see Creating Objects from Shapes). The hardscape object can modify the site model.
The following modes are available.
Mode
Description
Hardscape
Opens the Resource Selector to select a resource for placement; double-click a resource to activate it
Boundary Configuration
Creates a hardscape with a boundary configuration, defining an area with an optional border
Pathway Configuration
Creates a hardscape along a path
Pathway Edge options
For the pathway configuration, sets where to create the pathway in relation to the drawn polyline
Polyline creation options
Selects the method for drawing the polyline upon which the hardscape object is based; see Creating Polylines
Preferences
Sets the default preferences for the hardscape object
To create a hardscape object:
  1. Click the tool and mode.
  2. Do one of the following:
  3. ●        To use an existing hardscape from the resource libraries, click Hardscape on the Tool bar. From the Resource Selector, double-click a resource to activate it.
    ●        To create a custom hardscape, click Preferences. From the Hardscape Object Settings dialog box, set the default properties. The properties can be edited from the Object Info palette.
    The Stipple joint patterns are a processor-intensive action for large hardscape objects and can significantly increase regeneration time.
    When drawing a hardscape object with a curved boundary, speed the regeneration time by setting the 2D conversion resolution in Vectorworks preferences to low (see Vectorworks Preferences: Edit Tab).
  4. Click the appropriate mode in the Tool bar to specify the creation method of the hardscape object. Select whether to create a boundary or pathway hardscape object.
  5. The hardscape configuration can also be changed after creation from either the Hardscape Object Settings dialog box or the hardscape context menu commands (see Converting the Hardscape Object to a Boundary or Pathway Configuration).
  6. Click to set the hardscape object’s start point.
  7. Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the hardscape object is complete. Return to the start point (for boundary configurations), or simply double-click (for either pathway or boundary configurations) to finish creating the hardscape object.
  8. When classing the subcomponents of the hardscape object, such as the joints or tags, the class visibility of the specified class controls the visibility of the corresponding subcomponent. The class attributes are only applied to the corresponding subcomponent when the Use at Creation option is selected for the class. For example, if the Joint Class is set to the Site-Hardscape Comp-Main Joint class, and that class specifies a hatch Fill Style, edit the class and select the Use at Creation option to apply the fill attribute.
  9. If the hardscape 3D Type is set to Pad Modifier or Texture Bed Modifier, update the site model to apply the modification. Select the site model and click Update from the Object Info palette.
  10. If the hardscape is set to slope, specify the slope properties in the Object Info palette, and/or adjust slope indicator control points and reshape the corners in a 3D view (see Editing the Hardscape Object Settings).
To edit the hardscape object path in object editing mode, select the hardscape and select Modify > Edit Hardscape.
Concept: Hardscape Fills and Joint Patterns
Specifying Hardscape Joint Patterns
Editing Hardscape Fills and Joint Patterns
Applying Colors
Updating a Site Model
Setting Class Attributes
