DesignSeries00078.pngSpecifying Global Grade Object Preferences
Tool
Workspace: Tool set
Grade
●        Architect and Spotlight: Building Shell
●        Landmark: Site Planning
The grade indicator appearance for all grade objects in the file can be specified globally.
To set global grade object appearance:
  1. Click the tool.
  2. Click Preferences. Alternatively, select an existing grade object; click Settings from the Object Info palette, double-click the grade object, or right-click on a grade object and select Edit from the context menu.
  3. The Grade Settings dialog box opens. Click the Global Settings tab and enter the desired settings.
  4. Click Update from the Tool bar to update all grade objects in the drawing with the global settings.
Calculating Grade for a Site Model
Applying Object Attributes
Inserting Grade Objects
Analyzing Grade
