DesignSeries00088.pngAnalyzing Grade
Tool
Workspace: Tool set
Grade
●        Architect and Spotlight: Building Shell
●        Landmark: Site Planning
Grade objects can be used to analyze the slope objects in a drawing and identify critical slopes. Grade objects that are outside specified slope or elevation ranges are highlighted or selected.
To perform a grade analysis:
  1. Click the tool.
  2. Click Preferences. Alternatively, click Settings from the Object Info palette of a selected grade object.
The Grade Settings dialog box opens. Click the Global Settings tab and specify the grade analysis parameters.
Global attribute display of the slope indicator is described in Specifying Global Grade Object Preferences
Grade objects that do not meet the criteria are considered critical, and are highlighted and/or selected, as specified.
Calculating Grade for a Site Model
Inserting Grade Objects
Editing Elevation
Creating Loci from a Grade Object
Setting Site Model Graphic Properties
