DesignSeries00086.pngEditing Elevation
Mode
Tool
Workspace: Tool set
Edit Elevation
Grade
●        Architect and Spotlight: Building Shell
●        Landmark: Site Planning
If the elevation changes after one or more grade objects have been placed, there is no need to replace the existing grade objects. Change the elevation of one end of a grade object, or offset the elevation of selected (or all) grade objects in the drawing.
Elevation marker symbols must be at a valid scale to edit elevations. If the Edit Elevation dialog box does not open, increase the marker scale factor for the grade object.
To edit grade object elevation:
  1. Click the tool and mode.
  2. Click at the start or end of a grade object.
On the Edit Elevation dialog box, edit the grade.
Calculating Grade for a Site Model
Specifying Global Grade Object Preferences
Inserting Grade Objects
Analyzing Grade
Creating Loci from a Grade Object
