Select all
Command
Path
Shortcut
Select All
        Edit
        Document context menu
        Ctrl+A (Windows)
        Cmd+A (Mac)
The Select All command selects all visible objects in editable layers and classes. The active layer is always editable, but other layers can be editable if they are visible and if the Layer Options are set to Show/Snap/Modify Others. For more information about setting layer and class visibility and layer and class options, see Visibility columns, The Visibility tool, and Setting global visibility with class and design layer options.
To select all objects in the drawing area:
Select the command. The program selects all visible objects that can be modified. Each of these selected objects is displayed with highlighting. Locked objects are also selected so they can be unlocked for modification.
Selection and pre-selection indicators
Selecting objects
The Selection tool
