The Selection tool is located on the Basic palette.
Use the Selection tool to select objects for the next command or edit operation. The Shift key and the Alt (Windows) or Option (Mac) key are modifiers for selection actions. Create rectangular, lasso, or polygonal marquees around objects to select single or multiple objects. The following table describes the various selection methods.
Method |
Selection action |
Click |
Standard selection method; selects a single object only |
Option-click (Mac) or Ctrl-click (Windows) |
Creates a copy of the object and places it directly over the selected object, unless the preference has been disabled (see Vectorworks preferences: Edit tab) |
Shift-click |
Selects multiple objects as each object is clicked; also can be used to deselect one or more objects without affecting other selected objects |
Option-drag (Mac) or Ctrl-drag (Windows) |
Places a copy of the object where the mouse button is released; a “+” displays beside the cursor to indicate a duplicate is being made |
Rectangle, lasso, polygon marquee |
Selects all objects that are completely contained within the marquee |
Shift-marquee |
Reverses the selection status of objects inside a marquee; if objects inside the marquee are selected, this method deselects those objects |
Option-marquee (Mac) or Alt-marquee (Windows) |
Selects all objects that the marquee passes through, as well as those contained within the marquee |
(on the Edit menu) |
Deselects everything that is currently selected, and selects all visible objects in editable layers and classes that are not currently selected |
Double-click |
Reactivates the working plane on which a planar object was created; may also have other behavior such as symbol editing or polygon reshaping, depending on selected settings |
Select Vertex in Object Info Palette (context menu command) |
For vertex-based objects, selects a single vertex for editing from the Object Info palette; see Editing vertex-based objects |
Activates the object’s class, layer, or both (as necessary) and selects the object, even if the object could not normally be selected due to a different layer scale, or the current class or layer option settings |
To deselect all selected objects, double-click the Selection tool, click in an empty area of the drawing, or press the “X” key twice in rapid succession.
