DesignSeries00031.pngUsing slab styles
Unstyled slabs can be created; in a new file, the default unstyled slab includes a single component. The attributes of an unstyled slab can be changed from the Attributes palette. The use of slab styles, however, facilitates drawing slabs by saving the slab preference settings so they can be easily applied to other slabs. Slab styles are resources that can be imported into other files and shared as office standards. Slab styles, textures, and hatches are provided in library files (a selected slab style and associated resources are automatically imported into the current file, and display in the Resource Manager). Setting and saving the dynamic height information of a slab in its slab style is a convenient way of automatically setting the defined height condition when using slabs with stories.
Unused slab styles can be purged; see Purging items from a file.
Concept: Resource libraries
Creating slab styles
Editing slab styles
Applying slab styles
Deleting and/or replacing slab styles from the Resource Manager
Replacing slab styles from the Object Info palette
Slab properties
Creating slabs
Setting up the building structure with stories
