Spot00066.pngBridle preferences
Command
Path
Bridle Preferences
Spotlight > Rigging
Set the bridle preferences prior to inserting bridles in the drawing. Applying one of the Default Bridle Parameters ensures that all subsequently placed bridles have at least one dimension in common, to facilitate planning and assembly. Specify the default dimensions and parts. Optionally, enable the use of structural members as house rigging points. The settings apply to the current file.
The diagram indicates where the parameters are located.
To set the bridle preferences:
1.      Select the command.
The Bridle Preferences dialog box opens.
2.      Specify the default settings for bridle objects.
Managing bridle parts
Inserting bridles
Bridle properties
Adjusting the bridle configuration
Creating structural members
