The Structural Member tool has the capability to insert straight and polylinear structural members composed of a variety of common materials and shapes, and to build networks of associated members. Structural members can be aligned with the layer plane or a working plane, as needed.
The following modes are available.
Mode |
Description |
Column Insertion |
Inserts a vertical member |
Linear Insertion |
Inserts a linear member |
Poly Insertion |
Draws a structural member using the selected polyline creation options |
Polyline creation options |
For Poly Insertion mode, selects the method for drawing the polyline upon which the object is based; see Creating polylines |
Column Height |
For columns with both the Start Bound and End Bound set to Layer Elevation in Structural member settings, enter the column height |
Auto Join Members |
When selected, automatically joins connected members and maintains the association between the member being moved and adjoining members; members can be joined to another member’s start or end point, centerline or edge. Associations are maintained for copied and duplicated objects, including objects moved to a different document. |
Preferences |
Opens the Structural Member Settings dialog box to set the default preferences for structural members |
Mode |
Tool |
Workspace: Tool set |
Column Insertion
Structural Member
● Architect: Building Shell ● Spotlight: Rigging |
To create a vertical structural member:
1. Click the tool and mode, and then click Preferences to set the object defaults (see Structural member settings). Most of the properties can be edited later from the Object Info palette.
2. Enter the Column Height on the Tool bar.
3. If Auto Join Members mode is enabled, as you move the cursor over an existing structural member, the object is highlighted, indicating that it can be associated. Click to place the structural member; it is inserted by its base.
Mode |
Tool |
Linear Insertion
Structural Member
To create a linear structural member:
2. If Auto Join Members mode is enabled, as you move the cursor over an existing structural member, the object is highlighted, indicating that it can be associated. Click to place the structural member’s start point, and click again to place the end point.
Mode |
Tool |
Poly Insertion
Structural Member
To create a a structural member by drawing a polyline:
2. If Auto Join Members mode is enabled, as you move the cursor over an existing structural member, the object is highlighted, indicating that it can be associated. Click to set the starting point of the structural member, and then click to set each polyline vertex. Double-click to finish creating the structural member.
For information on using the polyline creation options, see Creating polylines.
