ArchSpot00011.pngStructural member settings
Structural member properties can be set in the Structural Member Settings dialog box before the structural member object is inserted in the drawing; access it by clicking the Structural Member tool and then clicking the Preferences button from the Tool bar. These preferences serve as the new default for structural members inserted in the drawing until the preferences are changed.
To set the structural member settings:
1.      Click the Profile tab and set the parameters. The Member graphic reflects the Member Type but not the shape.
2.      Click the Geometry tab and set the parameters. The alignment graphic indicates where the Axis Alignment point is located.
3.      Click the 2D Attributes tab and set the parameters.
4.      Click the 3D Attributes tab and set the parameters.
Creating structural members
Editing structural members
