DesignSeries00036.pngTitle Block Manager
Command
Path
Title Block Manager
File
For files with title block border objects already added to the layers, the Title Block Manager provides a means of simultaneously editing multiple title blocks in a project. You can mark layers for inclusion in the current file and in additional external files. Edits to title blocks made within the Title Block Manager apply to all the title blocks in a marked set, and some edits, such as edits to project data, apply to all title blocks in all the files.
To edit multiple title blocks with the Title Block Manager:
1.      Select the command.
Alternatively, right-click the title block border and select Edit from the context menu, and then select Title Block Manager.
2.      If other files are currently open in Vectorworks, a dialog opens; select whether to load only the active file or all open files. The Title Block Manager can access the title block data only from loaded files. Files can be loaded later from the Select Sheets dialog box.
The Title Block Manager dialog box opens.
TBM_IndetermStyle.png When layers with different title block border styles are marked for inclusion, parameters set by style for some of the marked layers and by instance for others, display the By Style/By Instance indicator in an indeterminate state. The values cannot be edited while in Multiple Edit mode.
3.      Click Select Sheets to Use to mark the layers for inclusion in the title block edits.
The Title Block Manager Select Sheets dialog box opens.
4.      Mark the layers for inclusion in the Title Block Manager operations. If this set of layers will be needed in the future, click Save to create a saved set for future use.
5.      Click OK to return to the Title Block Manager dialog box.
6.      Use Multiple Edit and Individual Edit modes as needed to set the parameters for the selected layers.
