Title block border settings
Click Title Block Border Settings from the Object Info palette of a selected title block border to open the Title Block Border Settings dialog box.
Creating plug-in object styles allows you to create plug-in objects, such as the title block border, with a combination of parameters that are determined by the style or by instance. Style parameters have a fixed value established by the style; instance parameters can be set independently for each instance of the object in the drawing.
The selected object’s settings are grouped into several panes of related parameters, which are listed on the left side of the Title Block Border Settings dialog box. Select each pane and specify the parameters.
Title block border settings: Sheet Border pane
Title block border settings: Sheet Zones/Grids pane
Title block border settings: Title Block pane
Title block border settings: Project Data pane
Project-wide data shared by all title block borders are managed from this pane; changes made to the Project Data pane of any title block border in the file are made to all title block borders in the file.
Managing project data
The Manage Project Data dialog box allows you to specify and order the fields on the Project Data pane.
Title block border settings: Sheet Data pane
Sheet-specific data are managed from this pane.
Managing sheet data
The Manage Sheet Data dialog box allows you to specify and order the fields on the Sheet Data pane.
DesignSeries.pngTitle block border settings: Revision Data pane
Depending on the length of the revision entries, they may need to be top-aligned in the revision section of the title block border; see Top-aligning revision and issue text in the title block layout.
DesignSeries00031.pngTitle block border settings: Issue Data pane
Depending on the length of the issue entries, they may need to be top-aligned in the revision section of the title block border; see Top-aligning revision and issue text in the title block layout.
Title block border settings: North Point pane
Title block border settings: Drawing Stamp pane
To display a drawing stamp, you must insert a text block in the appropriate location (see Editing a title block layout) and then assign that text block the Data Type Drawing Stamp (see Linking title block text to data records).
DesignSeries00032.pngTitle block border settings: Document Options pane
The revision and issue number options apply to all layers in the file.
Editing a title block border
Title Block Manager
Project revision and issue history worksheets
Changing plug-in object styles from the Object Info palette
