Creating a new data visualization
Command
Path
New Data Visualization
        View bar
        Viewport Object Info palette
A data visualization defines the objects that are included (the object criteria portion of the definition) and also the values from the object, or from other sources, to be used as the basis of the color scheme (the display criteria portion). This combination provides an extremely flexible method for visualizing embedded data in your drawing or model.
The Data Visualization menu is only available from the View bar when a design layer is the active layer.
To create a data visualization:
1.      Select the command.
You can also create a data visualization from the Manage Data Visualizations dialog box.
The New Data Visualization dialog box opens. Provide a name for the data visualization.
2.      Click Define Criteria to select the objects to include in the visualization. These are the items in the drawing that are of interest.
The Criteria dialog box opens. As described in Creating custom selection scripts, define the criteria.
3.      Once the object criteria are defined, select the display criteria from the Colors list; this determines the values or ranges of values to be differentiated by color or other attribute. The visualization will report the data selected here.
When new display criteria are selected, an alert opens, confirming that you wish to change all of the values in the list. This prevents you from accidentally deleting previously specified attributes.
4.      The list of values or ranges displays. For numerical values, choose whether to apply the visualization by value (By Values) or by numerical range (By Ranges).
5.      To quickly assign a range of colors to the rows, click Auto-Color. This option automatically determines a different fill color for all items in the rows.
6.      If setting attributes individually for row items, select one or more rows, and click Edit to specify the values and attributes or range values and attributes.
The Edit Attribute Value or Edit Attribute Range dialog box opens.
7.      Click OK to save the data visualization. The name displays in the Data Visualization menu.
If you created a new data visualization from the Object Info palette of a selected viewport, it is automatically applied to that viewport and any other selected viewports.
Applying a data visualization
Editing the current data visualization
Managing data visualizations
Viewing the drawing by data or by attributes
