DesignSeries00107.pngEditing curtain walls
The Edit Curtain Wall tool is in the Building Shell tool set.
The Edit Curtain Wall tool manipulates the frames and panels of curtain walls. Once a curtain wall is selected with the tool, the modes allow you to select frames and panels; delete frames and panels; add, split, and combine frames; move frame and panel sets along a wall; and edit frame and panel settings.
When a curtain wall is selected with the Selection tool, two context menu commands become available. The Edit Using Reshape Tool command activates the Reshape tool to reshape the walls as described in Reshaping walls. The Edit Using Edit Curtain Wall Tool command activates the Edit Curtain Wall tool.
Curtain wall grid patterns, including the location of frames and the attributes of frames and panels, are based on the grid definition in the Definition tab of the Wall Preferences dialog box or in the Curtain Wall Grid dialog box. Edits made to wall instances do not affect the grid definition. See Concept: Editing guidelines for curtain wall grids for a discussion of the interaction between the grid definition and any custom edits.
Mode
Description
Select Frame
Selects one or more frames
Select Panel
Selects one or more panels
Add Frame
Inserts new frames into the curtain wall
Split Frame
Splits a frame into multiple pieces, so that one portion of the frame can be independently moved, edited, or deleted
Combine Frames
Combines two collinear frames into a single frame
Move Grid
Moves an entire set of frames and panels relative to the curtain wall
Settings
Selected frame or panel parameters can be edited
Editing curtain wall frames
Editing curtain wall panels
Adding new frames to a curtain wall
Splitting curtain wall frames
Combining curtain wall frames
Moving a curtain wall grid
Changing selected frame or panel settings
Creating curtain walls
