The Convert Copy to Lines command works like the Convert to Lines command except that it first makes a copy of the object and then converts the copy into line segments. The original object remains intact.
To convert a copy of an object to lines:
1. Select the object to convert.
2. Select Modify > Convert > Convert Copy to Lines.
3. If the object can be rendered, select the wireframe, hidden line, or dashed hidden line rendering conversion option.
4. Click OK.
A copy of the object is converted into lines and each segment can be manipulated.
