The Join command can be used to join two single lines, two double lines, or two walls together. Joined lines intersect but remain as individual objects.
Object |
Command |
Specifications |
Individual Lines |
Join Join (No Trim) |
An individual line can be joined to another individual line |
Double Lines |
Join Join and Fillet |
Double lines can be joined to another set of double lines or to a wall. Double lines drawn with the Create Polygons option (set in Double Line preferences) cannot be joined. Only the line elements of double lines drawn with the Create Lines and Polygons option can be joined. |
Walls |
A wall can be joined to another wall or to double lines created with the Create Lines option (set in Double Line preferences). Walls will join to the line elements of double lines drawn with the Create Lines and Polygons option. |
