Flange Welding Symbol
To insert a flange welding symbol:
Click the Welding Sym-Flange tool from the Dims/Notes tool set.
Click to place the object in the drawing, and click again to set the rotation.
Once the object has been placed, its marker can be selected from the Attributes palette (see Marker Attributes).
