Different portions of the drawing can be selected for export to a 3ds file.
To export a 3ds file:
If 3D objects from only one layer should be exported, make that layer active. If only selected objects should be exported, select the objects.
Select File > Export > Export 3DS (3D only).
The Export 3DS Options dialog box opens; the options available on the lower part of the dialog box depend on which group of items were selected for export.
Select the types of objects to export, and then click OK.
Specify the export file name and destination, and then click Save.
