Importing
and Exporting in 3ds FormatThe Vectorworks Design Series products can both import from and export to the .3ds file format used by Autodesk® 3ds Max® software, version 3.0 and higher.
When importing a 3ds file, specify how the drawing components will be represented in the Vectorworks file.
To import a 3ds file:
Select File > Import > Import 3DS (3D only), and then select the 3ds file to import.
Alternatively, click the file to import and drag it into an open Vectorworks file.
The Import 3DS Options dialog box opens; the options available depend on the contents of the file being imported. Specify the file import options.
Click OK to import the file. The Object Info palette displays the image information.
