Changing the Instrument Label LegendAs instruments are placed on the light plot, the active label legend is assigned to them by default. However, the legend can be changed for a selection of instruments.
To change the instrument label legend:
Select one or more instruments.
Click the Spotlight > Label Legend > Assign Legend to Instruments command.
The Assign Legend to Instruments command is also available from the object context menu for selected instruments. Right-click (Windows) or Ctrl-click (Mac) to quickly access the command.
The Assign Legend to Instruments dialog box opens.
Select the new label legend for the instruments.
Click OK; the new label legend is applied to the selection.
The label legend can also be changed for an individual instrument by selecting the instrument, and then selecting the legend name from the Use Legend list in the Object Info palette.
Use the Find and Modify command to quickly generate a custom selection of specific instruments and apply the new legend to the selected instruments (see Find and Modify).
