Spot00062.pngLighting Instrument Color
The gel color of a lighting instrument is specified by the Color parameter in the Object Info palette or Lighting Device dialog box. Define the color by one of these methods.
●    RGB values separated by commas (such as 191, 49, 26); values must be between 0 and 255
●    Manufacturer color codes, by manufacturer name or abbreviation and color number (such as Gam 650, G 650, G-650, or G650)
●    Name of the color as specified in the file’s color palettes (see Applying Colors)
●    Web hex values prefixed by the pound sign (such as #003366)
●    Combinations of two or more colors (such as R46+R10); the resultant calculated color combination displays, just as when combining actual color filters. Invalid single colors are treated as white when calculating color combinations.
Acceptable manufacturer names and abbreviations are shown in the following table.
Manufacturer
Product Name
Abbreviation
Rosco
Roscolux
R, X
Rosco
Supergel
R, S, RS
Rosco
E-Color
E, RE
Rosco
CalColor
R, RC
Rosco
Cinegel
R, RCG
Rosco
Cinelux
R, RCL
Rosco
Storaro
R, RSO
Lee Filter
Lee
L
Gam
Gam
G
Apollo
Apollo
A, AP
GoboMan
GoboMan
GM
To draw a colored light beam for the lighting instrument, see Drawing Light Beam Representations.
The color setting can affect the display of the lighting device color, depending on the Spotlight preferences. See Lighting Device Setup.
Lighting Device Properties
Editing Lighting Instruments
Spotlight Setup
vectorworks.net
