Spot00058.pngEditing Lighting Instruments
Once lighting instruments have been inserted (normally, on a lighting position), many of the parameters of one or more selected instruments can be changed from the Object Info palette and Lighting Device dialog box, and the color, numbering, alignment, and other options can be controlled.
To select all lighting instruments focused on a particular focus point, right-click (Windows) or Ctrl-click (Mac) on the focus point and select Select Focused Lighting Devices from the context menu. The focus point and any other selected objects are deselected automatically to facilitate faster editing of the lighting instruments.
Lighting Device Properties
Changing Device Properties
Advanced Light Properties
Lighting Instrument Color
Instrument Numbering
Replacing Instruments
Changing the Instrument Label Legend
Refreshing Instrument and Light Position Data
Aligning Instruments
Find and Modify
vectorworks.net
