Spot00027.pngTruss Configuration Requirements
A great deal of flexibility is incorporated in the Spotlight truss object. However, in order to create a valid truss, the wide variety of configurations leads to certain restrictions in the application of truss properties.
If a truss is drawn that does not meet these requirements, an alert message is generated.
●    The width and height of the truss must be greater than three times the chord width
●    The truss hanging angle must be between -90° and +90°
●    A triangular truss must form a valid triangle
●    The chord diameter must be greater than zero
●    A pre-rigged truss cannot have lacing
●    A pre-rigged truss cannot be folding
●    Only box trusses can be pre-rigged
●    A folding truss cannot have top lacing
●    Folding is not allowed on a stacking truss
●    Top lacing is not allowed on a stacking truss
●    The top brace diameter must be less than or equal to the chord width
●    The side brace diameter must be less than or equal to the chord width
●    The connection interval must be greater than the ladder bar spacing
●    Ladder bar spacing must be greater than three times the top brace size
●    If the section is too small, lacing may not be drawn
Inserting a Straight Truss
Inserting a Curved Truss
vectorworks.net
