Spot00090.pngInserting a Stage Plug
The Stage Plug tool inserts custom shaped stage structures into a drawing. The type, shape, size, and appearance can be customized.
To insert a stage plug:
  1. Click the Stage Plug tool from the Spotlight tool set.
  2. Click the appropriate mode in the Tool bar to select the boundary creation method of the stage.
  3. For more information on the Polyline tool modes, see Creating Polylines.
  4. Click to set the stage’s start point.
  5. Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the stage object is complete.
The first time you use the tool in a file, a properties dialog box opens. Set the default properties, and click OK.
The stage plug can be reshaped with the Reshape tool; see Reshaping Objects. The stage plug parameters can be edited in the Object Info palette.
Formatting Stage Labels
Inserting a Stage Deck
vectorworks.net
