Panel Scheduling and DiagrammingThe Create Panel Schedule command generates panel schedules based on the circuiting information assigned to the file. If necessary, modify the dimensions and layout of the panel to conform to existing office standards.
To create a panel schedule:
Select Tools > Reports > Create Panel Schedule.
The Create Panel Schedule dialog box opens. Specify the panel schedule criteria and click OK.
If placing the schedule on the drawing, click at the desired location.
If placing the panel schedule in a worksheet, a worksheet is created with the panel name.
If circuiting changes are made, delete the outdated panel schedule and repeat the create panel schedule procedure.
