Joining Objects
Join Command
The Join command can be used to join two single lines, two double lines, or two walls together. Joined lines intersect but remain as individual objects.
Object
Command
Specifications
Individual Lines
Join
Join (No Trim)
An individual line can be joined to another individual line
Double Lines
Join
Join and Fillet
Double lines can be joined to another set of double lines or to a wall. Double lines drawn with the Create Polygons option (set in Double Line preferences) cannot be joined. Only the line elements of double lines drawn with the Create Lines and Polygons option can be joined.
Walls
Join
Join (No Trim)
A wall can be joined to another wall or to double lines created with the Create Lines option (set in Double Line preferences). Walls will join to the line elements of double lines drawn with the Create Lines and Polygons option.
Join
Join and Fillet
Join (No Trim)
vectorworks.net
